Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
blue coil and other damaged components
after a failed attempt to solder the blue coil, the components were all damaged or missing, the iphone is work well, just not picking 3g signal.
is there any possible solution in this case?
Score 1
2 Comments
John, any chance you could be posting a picture that shows more of the total damage straight on? That would help to identify those components.
by
tomorrow I put more photos of the damage in question.
thanks for the reply
by
Add a comment
1 Answer
Chosen Solution
John, right of the bat, you are missing at least three components. Two capacitors and 1 inductor:
C93 RF 1.0PF +/- 0.1PF 25V C0G 201
L17_RF 4.3NH+/-0.2NH (Little blue coil)
C95_RF 1.0PF +/- 0.1PF 25V C0G 201
The reason why you can get away with just bridging the inductor is because it is in series with the trace. Both caps need to be going from that same trace the inductor is on to ground. I attached the schematic for that as well. Zoom into the picture to visualize it more directly. The problem with this now is a:are your trance still okay and B; somebody with the right tools and the right skills need to do the soldering. It appears that this is what caused the issues in the first place. The parts are not expensive and are readily available at most electronic warehouses like Mouser.com or Digikey.com. Depends on where you are located.
Hope this helps, good luck.
Score 1
2 Comments:
this helps me to understand the problem, im from portugal and i dont know u possible do the soldering.
thank you so much .
by
John, I would be more than happy to help you out, but it probably cost you more in shipping than having it done somewhere in Portugal. Thank you for accepting my answer.
by
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 737
