2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
930 Questions View all
Why won't my computer turn on?
My computer will not turn on. It stopped working the week before Easter. The day after Easter, right after I ordered it a new battery online, my computer turned on again and started working. The new battery came in the mail a couple days later and after replacing my very old and very dead battery, my computer still worked. (I know my problem is not a battery/power adaptor issue.) After about a week, my computer died again and has not turned on since. I replaced the PRAM battery and that did not help. When I press the power button, the screen stays black and there is no start up chime. The front power light does light up however, both of the fans turn on and the optical drive starts to spin. I was able to get the optical drive to grab a CD, but I cannot get my computer to give me the CD back. The keyboard does not light up and is unresponsive. My computer behaved this way before I bought it a new battery or replaced the PRAM. At this point I have no other ideas of what could possibly be wrong with my computer.
Comments:
Did you get your system wet or drop it at some point during it's life? Other than replacing the battery have you done anything else, like replace the HD or add/replace the RAM?
by
This MBP model has a well documented issue with the NVIDIA GeForce 8600M GT graphic card. I would bring the computer at the Apple Store to check it out.
by
My computer has never been dropped nor has it had any liquids spilt on it. It is in excellent condition considering its age and only has one tiny scratch on it from a paper clip. I have not replaced the HD or RAM. I will have to wait a few weeks to take it into the Apple store, I am at school right now and the closest one is about 3 hours away. Thanks for the advice!
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Most of the time you get a distorted image, then blinking in and out with the NVIDIA GeForce 8600M GT problem. If you encountered this then you have a defective GPU. Sorry to say Apple may give you a hard time getting it replaced under the extended warranty. There was two lawsuits one by Apple against NVIDIA which they won, the other a small claims lawsuit against Apple who lost. Review both online before you go to the Apple store so you can bend the managers arm. You should be able to get the logic board exchanged out for a flat bench fee, once they determine it's the GPU problem using a special test tool (if they can get it to boot up).
Update
As of May '13 Apple end of life'd EoL this model and no longer offers any repairs or parts for it. You will need to go to an independent service center to have them re-ball and/or replace the GPU.
Score 1
Add a comment
Add your answer
Alayne Wing will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 218
