2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
MacBook Won't Boot Up
I have a MacBook A1342 and it won't boot up. At first, I thought the topcase was the culprit, so I replace the top case, and still nothing. Then, I thought the battery was dead, so I replaced that as well. Still nothing. When I plug the computer into the charger, the MagSafe illuminates with a green light, but when I try to boot the machine, nothing happens. The fan doesn't even spin. Anyone have any advice?
Score -1
Add a comment
1 Answer
Chosen Solution
Even if you have a strong green led on the AC adapter tip the magsafe DC in board could be the culprit. Did you test it ? Also did you try a known working AC adapter ?
If you have a multimeter find the two power pads (left side of the top case connector) and with the multimeter settled to DCV/20 put the black probe on any logic board screw for ground and the red prob on one of the power pads. With the AC adapter connected you should get 3.42 volts one one pad and 0 on the other. Any other reading means something is wrong with the power line. Disconnect the top case ribbon cable from its socket and redo the voltage reading on the power pads. If you then get the 3.42V you'll know that the top case is faulty. If you still don't get the right voltage then remove the logic board and check the magsafe DC in board and the main power fuse. When connecting or disconnecting anything on the logic board make sure the AC adapter and the battery are not powering on to the Macbook.
Score 1
Add a comment
Add your answer
Tyler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 845
