The Canon Powershot SD790 IS is a compact 10.0 megapixel digital still camera with built-in flash and a 3x Optical Zoom. It was released on March 2008.
10 Questions View all
camera reads, no memory card, same read with new card
how do i get the camera to recognize memory card.
to clarify, i am able to read the memory card using the computer, i can see the photos and data, and both cards work in other devices.
Score -1
1 Comment
clarence, just to clarify, it does not read the cards at all? You tried the cards in another device?
by
Add a comment
Chosen Solution
Look inside the SD card socket in the camera (use a flashlight) and check if all the pins are OK, check for misaligned, bended or corroded pin(s). The problem could be caused by a bad contact from the SD card to the connector pins.
Score 1
1 Comment:
I followed your advice and the pins appear to be in position and normal.
by
Add a comment
What size SD card are you trying to use? I believe that model can't use a SD card larger than 2GB. If it's greater than 2GB, it uses a different memory format and cannot be read.
2 Comments:
i've always used a 4GB, recently bought a 16GB and it also worked fine in the camera
by
As oldturkey03 asked, "clarence, just to clarify, it does not read the cards at all? You tried the cards in another device?"
by
Add a comment
Add your answer
clarence will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 302
