Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
White screen after opening the phone
I have 3gs iPhone,in a middle of a call it says No sim card installed I tried every possible solution : restore jailbreak and every thing.....
So I decided to open the phone to have a look on it components and see if something went wrong....
but the lack of experience helped find nothing.....
so I decided to use it as an ipod ..well.. I had put the phone together again and I did succeed but when I turned it on all I see it a white screen,
when I turn it on, I can not see an apple logo , but soon after two minutes I can see the white screen, Itunes recognize it and it is charging ,
I tried these solution from the guides here :
1-Hard Reset
2-Replacing the LCD
3- Changing the battery
4- Disconnecting the logic board for half an hour and more even
5- Restoring the firmware
6- Restoring from a backup
7- Changing The Display assembly
8-Cleaning the logic board
9-Searching for any thing wrong with logic board after removing it adding to the removal of the metal things there,
Still When I turn on the phone its white screen
help please,this phone is driving me crazy,
Thanks in advance
Add a comment
1 Answer
I could be wrong but I think a white-screen happens if you connect the battery before the screen flex cable. This happened to me the first time I changed a screeen and I had to fit another new one.
1 Comment:
Thank you for the fast reply , but I did connect my logic board to another device with the battery disconnected but it maintained the white screen , thanks for the help.. and if you have anything else to help me with...since you had the same problem, and if I may ask you did you succeed fixing you phone, coz I bought three LCD displays and assemblies .. they are all working perfectly fine... I love my iphone and I wanna fix it .....thank again
by
Add a comment
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 3
All Time: 104
