Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Questions View all
Question Closed
Broke the LCD data cable connection on the logic board.
While the replacement of the HDD to SSD went smoothly, putting the whole thing back together was another story. After installing the SSD, as I was finishing up the reassembly, I managed to put a little too much force on the display connector, I broke the receiving connection on the login board. I beleave it's called a LCD data connection. Since the disaster I have contacted multiple apple repair shops, and they tell me either they will not accept the job because of its difficulty, or it will cost me an upward of $1,200 dollars to replace the logic board.
Any help or ideas are appreciated.
Thanks,
Paul
1 Comment:
pchun73, post a good image of the damaged connector on here. Lets see if we can help you with that. You do have the connector? What do the connections look like? Any damage to the traces on the board? You do know how to solder or know someone that does?
by
Add a comment
How about trying to replace the display cable? I've found original pieces coming from Hong Kong (I just replaced my keyboard like that).
http://www.ebay.com/sch/i.html?_trksid=p...
hope this helps
1 Comment:
vendemechiles, its the connector soldered to the logic board " I broke the receiving connection on the login board." a new cable will not fix this.
by
Add a comment
It's pretty straight forward repair if you have the proper soldering skills. If you don't then leave it to the pros..
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 812
