Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Questions View all
Question Closed
The touch is not working
I have the same problem. I was trying to replace my friends iphone 4s screen (cracked) and I took it apart but then realized that the screen replacement was missing the LCD (just the front cover glass). So I put it back together and I know the first time I realized that I didn't pull the display ribbons all the way through because they couldn't reach the connections. So I dismantled it again to fix it and put it back together and it turns on and works but the touch is not working. Do you think just need to get a new screen to get it to work because the digitizer ribbon maybe damage? I tripled check to make sure all the connection were good and they were.
Add a comment
1 Answer
Did you lift up the little latch that holds the ribbon in place, or did you just pull it out?
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 88
