Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
Water damage: Light and proximity sensors not working. What to do?
I dropped my iPhone into the water and now everything is working except both the light sensor and proximity sensor. So on which piece of the are they located? Is this one part I can replace or do I have to buy a bigger and more expensive piece? Or should I first check the connection cables if they are damaged by the water?
Sorry, I'm very careful because I never opened an iPhone before and since I rely on my daily basis so much on this device I don't want to damage anything.
Comments:
I noticed you never got an answer to this. Are you still having this problem?
by
Yes, my phone can still not make any use of these two sensors. Every few weeks I also have a series of random crashes in which it turns itself off.
Do you have any suggestions or links to helpful sites?
Thanks.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Try
opening (carefully follow guide) and cleaning any corrosion with electronic contact cleaner, and a soft bristle brush. Check both sides of the board. Use 99% isopropyl(nothing less) alcohol to dry it.
Reassemble
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Add a comment
Most Helpful Answer
Apophazz, I bet your ribbon is damaged. They a fragile and a slight bit of corrosion can cause it not to work, or even a kink. This is an easy repair. I have done many. You just need to take your time and be patient with it.
Score 1
Add a comment
Add your answer
apophazz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 3,938
