Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
My iPhone 4 does not turn on or charge.
My iphone 4 does not charge or turn on and is not recognised by iTunes or a computer. I have tried the hold home button and the lock button for 30 secs - 1 minute but still nothing. I switched the battery with my girl friend's battery and her iphone worked yet mine did not even with her battery. I don't know what else to do, this is really frustrating as I have a lot of content on my iPhone not backed up. I'm really desperate, can anybody help...
Score 8
4 Comments
Did anything happen to the phone or did it just stop working? do you have a multimeter and can you check the battery contacts for power?
by
it just stopped working overnight and no i do not have a multimeter
by
see i am having this same problem and no one is answering these kinds of questions... i replaced EVERYTHING in my iphone... nothing, no response... but i think the battery connector might be bad too im gonna check...
by
I have the same problem. I replaced the battery and the dock connecter but to no avail.
by
Add a comment
Chosen Solution
Hold the HOME and POWER (aka SLEEP) at the same time. An Apple logo should appear in 10 - 20 seconds. Relase both buttons, wait about a minute, and your phone should be back to normal.
Occasionally it may be necessary to toggle the Mute switch a couple of times before above Step. No one is sure why, but sometimes it helps if just holding the 2 buttons doesn't work.
https://discussions.apple.com/docs/DOC-3...
Score 13
12 Comments:
I held the Home & Power butttons at the same time as you said and my Iphone 4 did come back on, but after it booted up completely, it again turned its self back off so I tried again and so far so good! I really wish I'd never gotten an iphone to begin with!
by
It helped me too.
by
thank you very much it works
by
it works thank you
by
Wow. After a few hours of black screen and not even charging. I thought my phone would never turn back on again, but I tried toggling the mute button a few times like you said and it turned on immediately without me hitting any more buttons. Thanks!
by
Show 7 more comments
Add a comment
I recommend replacing the Charging Port,it has worked for me before.
Score 1
1 Comment:
I have the same problem? Could the charging board b fried?
== Update ==
Mine wasn't dropped I just plugged it in to charge it @ about 48% & it continued to drain the battery. I even tried several different chargers & my laptops USB with the same out come...a paper weight. I can c two little darki spots on the dock/charging board hence y I thought it may have fried itself?
by
Add a comment
It probs not connected internally. I opened an iPhone and u need to push down on the battery to make sure its in b/c i dropped it and it loosened
Add a comment
it might be the charger port
Add a comment
I had given my iPhone4 for a service for changing its broken display. After that I used it for a day and then the problem started. It was showing the apple logo and was going off whenever i tried to switch it on. Tried power button+home button restart, same response.
Here is how i solved my issue in a DIY way.
I didn't have an iPhone screw driver. So I used a pointed knife to open the two screws at the bottom of the phone, near to the speaker and microphone holes. Slided the back cover of the phone(back cover i mean is, the part of the phone which has a printed apple logo on it). After sliding up, it should come out in your hand. No force needed.
Now the back portion of your phone is open exposing the battery, some antennas and contacts. You will be easily able to locate the battery connector(small rectangular, stainless steel with again a screw) Use a proper star screw driver to open the connector or if you are my type, use the 'magic knife'. I was not worried about the scratches which are going to come on the screw because, This screw is inside, my phone is pretty old, screw is cheap, service centers were far, didn't have time and repairing was so urgent.
While opening this connector screw, you should be a little careful because when you remove the connector screw, there is a small piece of metal which will come out, this is the contact for antenna. Which means, the battery connector and the antenna, these two things are fixed with a single screw. So when the screw is removed, you will be able to take out the clip-on 'battery connector' along with this small piece of metal. Open up the connector, see whats inside, use a dry brush to remove any dust or debris stuck inside the connector.
In my case, I was lucky enough to locate a dried piece of glue which was disturbing the connection.
Clear it off. Put back the connector by aligning it in place and giving it a push. Now at this point, if you are to eager to see whether the phone is working, go ahead, switch it on. Any luck? If not, remove the clip on connector and visually align it and put it back again after a little more cleaning. This time, press and hold the connector with your finger to give it a proper pressure to help the contacts touch if any loose contact issue is there, and switch it on. It should work. Put back the screw. Avoid tightening more if don't have the proper tool. In my case, my Passion of working with automobiles and heavy stuffs, I had a habit of over-tightening and breaking these delicate electronic components. So don't do that, Knifers, leave the tightening part for later. Some day you might come across a proper tool, that time you may open your phone again and tighten the rest. For time being, just make sure it is not too loose to stick out to touch the cover.
Time to put back your phone in one piece. Place the back cover cover a little up, slide down to lock, put back the two screws at the bottom. Hope you should be good to go.
Contact me via call,sms or whatsapp, if you got any doubts or to discuss any interesting DIY fixes like this. I dont have any blog or website. This is my first attempt to write a matter in such a blog. Happy living Dears..
Roshan K Kumar
+919895498407
Add a comment
i have an iphone 4 i have put a brand new charging dock in there but everytime i try and charge it up there is no life or nothing on the phone it just gets hot is the logic board or something i could do with some input please people
1 Comment:
it come on and off when i put it on a charge help ppl
by
Add a comment
Add your answer
Grayson Utuk will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 28,164
