Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
iPod Touch 4th home doesn't work
My itouch 4th home button doesn't work. I wanna fix it just by following iphone 4th guide. But I get some problems. Is it the same steps as that guide? And how to open my itouch?
Add a comment
Chosen Solution
It is not, Here is the guide for the iPod touch 4th generation.
Cheers
Add a comment
this is an easy fix. you just need to lift the glass (without breaking) and look at the home button. there should be a black dot around there somewhere which you need to super glue back on the yellow tape. you can also buy the yellow tape with black dot
http://www.aliexpress.com/item/power-sle...
2 Comments:
this part appears to be for an iPhone
by
I work on these devices professionally, and I can tell you the sample they have is for an iphone but you're not buying the iphone part, you're just buying the yellow tape with the black dot which is actually an interchangeable part of a part from many devices that click when you press (I've seen it on some htc phones, and mostly iphone 4,4s, and touch 4)
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 690
