Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
battery doesn't last after pop spill
long story short, my Mac got a ill Pepsi spilled on it a month ago. when it happened, the ac adapter light would be dim when you plugged it into the Mac but the Mac was dead. it made a small fan sound when you pressed the power button but nothing. it would come on only after you opened it up and unplugged the battery and plugged it back in. I did that a few times after the spill. it has seemed to have gotten over that but now the battery can't seem to last a day without dying and gives you the beeping on boot up when you plug it in and power it on. I did the best I could to get the pop out after the spill, it didn't get much inside that I could tell. I don't know if the battery is shot or something else. it runs fine as long as it gets charged more than it use to be. what could be wrong? I need my Mac and can't afford a new one. thanks all.
2 Comments
What kind of beeping does it give you?
by
it boots up, on the apple screen, the loading bar fills up, then it stops and gives you 3 beeps, pauses, then 3 beeps. it does it when it is completely out of power and you have to plug it in in order for it to turn on. does this help any?
by
Add a comment
1 Answer
Chosen Solution
The three beeps indicate a RAM error. Try reseating your RAM.
Score 2
1 Comment:
it only does that when it runs completely dead and u boot up while charging, I've been told that the needs to be reseated so ill try that, would that any affect on the battery prob?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 174
