Is slow charging with replacement battery a symptom?
I purchased a battery on ebay, it wasn't until I started searching for the problem that I found this site... sorry.
The original PN of the 3gs that I removed is 616-0431, I don't know what the PN was of the battery that I installed. I will probably need to crack it open again.
The problem that I am seeing is that is senses the charger (tried charger and notebook USB, same problem). But, it will add about 1% per hour... maybe.
If the charging component in the iPhone is toasted, would it be either working or not. And, does this mean that there is a problem with the battery instead.
Unfortunately the battery that I had pulled from the 3GS was completely gone and the iPhone wouldn't bootup, even when plugged in. So, I can't put the old battery in to test.
I've read bunches of posts, about dead batteries, incompatible etc. But haven't found one specific to a slow charge. Is it a bad battery and does iFixit sell one that would be compatible?
thanks in advance,
j
