Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
on board wifi contact is broken! any way to find alternative?
Hello!
my friend iphone 4 got a massive damage... i replaced almost every part of the phone(everything works perfect!!) but there is one problem - the wifi contact point is broken on the board so there is no place for the antenna to touch... here is a picture so you can understand better what im talking about:
http://i.imgur.com/cYmyFcP.jpg?1
is there any way i can connect the wifi antenna to an alternative point on the board? soldering is not an issue...
thanks a lot!!
Score 1
Add a comment
1 Answer
Chosen Solution
this should help you a lot
http://img20.imageshack.us/img20/3396/ip...
You will probably need to solder a wire from the metal plate to the line
Score 2
Comments:
Excellent post & diagram. Bookmarked for future reference, if needed. Kudos
by
Add a comment
Add your answer
Yogev Ifergan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 469
