Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
on board wifi contact is broken! any way to find alternative?
Hello!
my friend iphone 4 got a massive damage... i replaced almost every part of the phone(everything works perfect!!) but there is one problem - the wifi contact point is broken on the board so there is no place for the antenna to touch... here is a picture so you can understand better what im talking about:
http://i.imgur.com/cYmyFcP.jpg?1
is there any way i can connect the wifi antenna to an alternative point on the board? soldering is not an issue...
thanks a lot!!
Score 1
Add a comment
1 Answer
Chosen Solution
this should help you a lot
http://img20.imageshack.us/img20/3396/ip...
You will probably need to solder a wire from the metal plate to the line
Score 2
1 Comment:
Excellent post & diagram. Bookmarked for future reference, if needed. Kudos
by
Add a comment
Add your answer
Yogev Ifergan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 486
