Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Questions View all
Question Closed
Temp sensor connector broken, where to solder? HF/E1, see picture
Dear,
Someway or another I have managed to broke the connector of the temp sensor on my macbook air A1237.
Now I want to repair it, and solder all the cables back to the connector, but I don't know where they should be soldered as it is not clear.
I have marked the cables on the board with 1,2,3 and 4.
Can someone please tell me where to solder them, see picture:
Thank you very much in advance for your help !
Kind regards,
Benwake
EDIT:
2 Comments:
When you say "solder them back" what do you mean, see that the board where they are connected is not connected to the main board but until I can see from another angle I can't really help you very much.
by
Hi,
Please check the image above.
I need to know where to connect the cables from the square part to the connector.
Thanks in advance
by
Add a comment
1 Answer
this shows it
You have it in the right spot, just figure out how it was attached. I don't think it's soldered, probably glued.
1 Comment:
That is actually my problem, I don't know how it was attached. I should need to know which cable from the connector goes to where on the square piece :/
This is actually what I am doing now:
http://benwake.com/upload/SDC16400.JPG
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 966
