Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
No Service when 3G is enabled.
Dear iFixit,
I am having a problem for a bit with my old 3GS: I get very poor connection when 3G is enabled. Basically, I have some network for a few minutes (10-15, it varies) then switches to "searching" and then "No Network". I usually don't get any network back.
It is interesting to note that when 3G is off, I have absolutely no problem getting a stable GPRS/EDGE connection.
I am currently running iOS v6.1, but I have this problem for ages.
Therefore my question is: Is there a different antenna for 3G and EDGE/GRPS? Would you recommend changing it?
Regards,
Score 1
Add a comment
Most Helpful Answer
Hello,first off all sorry for bad eng. but ill try to help you
So i saw a lot users od iphone have problem with iphone 3g/gs. No service on 3g network or when its off,i have that phone also and i have solution that worked 100%
problem is on signas switcher that is located on this picture you can see them: lower part of iphone.
http://i87.servimg.com/u/f87/13/27/39/62...
So here it is,take a hair dryer,a turn it on,heat this chips for about 10 sec,then whit your fingers push chips on logicboard,get iphone back on,go to settings-reset then reset network settings,and its workig :)
if its now working try to heat and push chips again
please share this solution becouse i cant see any other solution for this problem
and please correct my words if there is something wrong
Score 2
2 Comments:
jurica, nice answer, but can you describe the location of the "signas switcher" a bit better?
by
I do it by the way,but it does not work.
I must push chips on logicboard more powerfully?
by
Add a comment
Hi,
i had the same problem with an old 3GS. It was an error in the logic board, without a chance to fix it.
Add a comment
can this problem be solved in same manner for android phones?
Add a comment
Add your answer
Ace Spizzer will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 8,264
