Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Wont connect to wi-fi after screen replacement?
I just replaced my iphone 4 screen and LED yesterday and besides a few minor issues with the color, it was working great. Until I got home and tried to conenct to my home wi-fi. It wouldnt even register that the connection was there! I made sure it wasnt a problems with my other devices like my laptop, and it wasnt. Anyone know whats up?
Also, i looked around a bit already, and there are no issues with the service and I haven't tried seeing if it will connect to other people's wi-fis yet. But it worried me so I thought I'd ask.
Add a comment
Chosen Solution
anders do you no your talking about the reception connector pin and not the wifi!!!
this is you problem make sure the tiny metal peice is on it as shown in pic and that the large screw is holding it on
Add a comment
Have you checked if the wifi-connector (under the battery connector and the tiny clip that connects to the rear panel) is connected properly? Have the pins on the wifi antenna(located on the speaker) been damaged?
You should check these things and replace the antenna if the pins are broken.
1 Comment:
I have not checked, thank you. Do you possibly have a picture or something I could look at, because I went somewhere to have it replaced.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,198
