Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
touch screen doesn´t work
I was changing my home button today and when I was puting everything back I tore on of the flex cabels from lcd touch screen.
the one on the right side.
Does anybody know if it is possible to change just the cable or do I have to change whole lcd? Thank you!
Add a comment
1 Answer
Chosen Solution
Michal, sorry but you will have to replace the whole assembly.
Score 3
will be this ok? This is the cabel which is tore:
"Replacing the display assembly will give you a new front glass panel, digitizer, and LCD. The LCD is adhered to the glass at the factory and the two parts are not separable without damage." there are vendors out that sell separate parts, but unless you have very expensive tools, you can not separate the assembly. It's best to look at something like this By the way, the part that you were looking at is only a screen protector ;-)
Ok, thank you :)
you are welcome, good luck.
Add a comment
Add your answer
Michal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 112
