RCA 52" rear projection HDTV.
9 Questions View all
step 4: removing the connectors BL111 and BP005?
i have all but the BL111 and the BP005 connectors unplugged and i cant see to them those two out. How do i unplug these? It looks like in the pictures you just pulled the "tape" out of the sockets?
Thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Dan, you are absolutely correct. The two flat ribbon cables that attach to BL111 and BP005 just pull straight out of the connector. All you have to do is to pull the ribbons in the direction of the arrows.I attached a few images and will also edit the guide. Hope this helps, good luck.
Score 1
Comments:
That did it, except both ends of the ribbon came out on both connectors...
by
That is okay. You'll find that they reinsert the same way, it is actually pretty easy. Thanks for accepting my answer.
by
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 302
