Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Do I need a whole new front assembly or just a new screen?
I dropped my iPhone 3G on cement and got the spider cracks emanating from one corner. The touch screen does not work, however when I plug it into a usb port, I get a totally white screen. Should I order JUST the screen replacement or the entire assembly? I do not want to replace the screen only to find out I have to remove it again and replace the digitizer as well, however, 70 bucks is 70 bucks....
- Ryan
Score 1
Add a comment
Chosen Solution
Best Bet: Replace Display Assembly
I suggest you replace the entire display assembly with a new one from Ifixit; part IF137-008-1. It is quick and pretty easy to replace. Just replacing the screen and digitizer is doable but very difficult and time consuming. If you want the phone back in operation quickly replacing the display assembly is the way to do it.
Please note that I'm not yet an experienced small device repair technician. What you read above is just my opinion. I'm basing it on attempting to replace the screen and digitizer of an iPhone 3G for a friend with parts from a different source, and failing. Then I ordered the display assembly and that worked out great. The friend is happily iPhoning. It was gratifying to see it all work so fast. --Bob
Score 2
1 Comment:
Thanks for the feedback. I just ordered the whole display assembly.
by
Add a comment
Received the Assembly VERY quickly and just installed it. It is charging as I type this and it looks like all is well thanks @cochranb and thanks @ifixit!
Add a comment
Add your answer
rcfuller will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 2,502
