Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
Upper LCD replacement with iOpener
I've to change and upper LCD for a Nintendo 3DS and I think to use the iOpener to heat the upper display front panel instead a hair dryer or heat gun.
Is it a good idea or is there a serious risk (for the cam and HP below the panel) ? Thanks
Add a comment
1 Answer
Chosen Solution
RogerVador, interesting approach :-) Yes, you should be fine. It does not really matter where the heat source comes from. The iOpener should work for this as well. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
RogerVador will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 239
