Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
light glows at the front, hd spins, fans start,nothing furter happens
I have the same issue. Spilled a cup of tea into the backside of the mbp while the machine was on. It shut off instantly.
Some tea in the bottom of the machine, logic board got wet.
Disconnected battery and left open to dry for a couple of days.
Now when switching machine on, light glows at the front, hd spins and fans start to run at max speed after 10 seconds. Nothing furter happens, screens is black, keyboard is not lit up and the fan keeps blowing like crazy.
Battery charges normally via magsafe.
Cleaned the motherboard with isapropelyne 99.9% but no improvement.
Is my logic board dead or could it be there is a fuse blown that can be fixed?
Regards bertt
3 Comments
Try booting from your install disk to eliminate a damaged HD as source of problem.
by
Tried that. Didnt work. Now disk is stuck as keyboard does not work (eject)
by
Booting with the mouse (or a mouse) button held down should eject the optical disk (you can use any USB keyboard or mouse) to do this.
by
Add a comment
1 Answer
Chosen Solution
The fan runs because one or more sensors are blown - default is to go in to max rev mode to keep from cooking the CPU. Try an external monitor to see if the black display is only an internal video chain issue.
If an external monitor doesn't work you've killed the logic board and a replacement is called for.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 135
