Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
HELP! Home button is not working due to water damage
I have recently dropped my iPhone into my cup of tea and now the home button does not work. The top half of the phone did not come into contact with any water, it's just the bottom half.
The phone still functions, however the home button does not work and the speakers are a little crackly (i'm not to bothered about the speakers, I can live with that!)
When I place the button to my ear I can hear a a sort of noise - any ideas on what this may be?
It's been on the radiator..in a bag of rice, you name it, i've tried it!
All in all, I was wondering if anybody could suggest any ideas or solutions. Do i need to get it repaired professionally or are there any solutions that I could try at home?
Any ideas would be much appreciated
Score 1
Add a comment
Chosen Solution
Gwen, the very first thing to do is to clean your phone. Rice and the radiator will not prevent any corrosion, nor will it clean the phone. Use this guide to disassemble your phone. It is not as difficult as you might think. Once it is disassembled, use this guide to properly clean your phone. Once cleaned, replace your battery and re-assemble and re-evaluate. It is possible that you need to replace the home button or even the home button flex, follow this guide. Like I said before, it is not as difficult as it might appear. Hope this help good luck.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
iPhone 4S Logic Board Image
Guide
iPhone 4S Logic Board Replacement
Difficulty:
Difficult
1 hour
iPhone 4S Home Button Ribbon Cable Image
Guide
iPhone 4S Home Button Ribbon Cable Replacement
Difficulty:
Difficult
2 - 3 hours
2 Comments:
I will certainly give this a go, thank you so much!
by
Gwen, thank you for accepting my answer. Just follow the great ifixit guide and you should be okay. If you have any issues after that, let us know with new questions:-)
by
Add a comment
There could be damage/corrosion on the home button circuit or on the dock (The home plugs into the dock module, which plugs into the circuit board). If you are comfortable and have the tools, you can open up the phone and have a look at the dock to see if you see nay corrosion. Examining the home button circuit will be a little trickier, as you have to completely take the phone apart to see the entire home button circuit. If you do see any corrosion, you can attempt to clean it using a brush (like an old tooth brush) and Isopropyl Alcohol.
If you are not so comfortable with taking it apart, there are several repair company's out there that specialize in iPhone repairs and would be able to help you. They are just one Google search away.
1 Comment:
Thank you for your feedback.
So is that serious or can it be resolved easily? and is there any way that this problem can be resolved at home? I live in Wales and there aren't many reliable phone repair shops around so I may need to go further afield!
by
Add a comment
Hi Gwen you ever get this sorted?
Add a comment
Add your answer
Gwen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 30,464
