Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Question Closed
bad hard drive in intel iMac?
I have an older imac I recently purchased used. It worked fine for a few months, mostly for graphics and internet work. It had been freezing and crashing and sometimes sticking on either the blue, grey, white screens and sometimes the apple with spinning wheel or question mark folder....yep all of these...and sometimes it would start right up. Ohterwise it was a hard start/shutdown with the power button.
I've done the homework and tried all the external fixes as well as firewire target mode but at his point nothing is recognizing the internal drive. Not utilities and not target mode...I can boot from a snow leopard install but cannot reinstall, nor will it recognize the internal for start up.
I'm not very 'terminal' savvy or other stuff like 'single user' mode but even safe and single user did not seem to work out for me. I believe I tried hardware test also which did not run.
Can I just go ahead and replace my hard drive, reformat and start from scratch or is it possible that these issues could be from motherboard or cables. I wouldn't want to buy and replace the hd if there could be another fix. Hope that's all though...I can do the HD replacement no prob!
Thanks in advance!
Add a comment
Chosen Solution
If your machine is booting OK from your system installation disk, it sounds like you just need to replace the hard drive. Get one that can be jumpered down to 1.5 Gb/s.
Score 3
1 Comment:
Could you elaborate on this... "Get one that can be jumpered down to 1.5 Gb/s" I'm not quite sure what 'jumpered down' means... or perhaps point me in the right direction.
Thanks!
by
Add a comment
If I am not mistaken the older iMac computers ran hard drive with data transfer rates of 1.5GBps and new drive technology drives run at 3GBps or 6GBps. Some drives will have a jumper setting on the back that allows you to run at the lower spec transfer rates. Technically, you could run a 3GBps or 6GBps drive without the jumper feature, but you would most likely experience a performance bottleneck.
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 364
