iPhone 3G freezes at startup
Hi,
got an Iphone 3g 16g here which is stuck at the Apple logo.
First it showed me the icon to charge the Phone, so I connected it to my computer. After a few minutes the Phone tried to boot up but it got gets stuck at the Apple logo. It doesn't reboot and the worse: it doesn't respond to any buttons.
So going into recovery or DFU mode seems to be impossible. Itunes doesn't recognize the iPhone.
The buttons are 100% working and i cant even do a hard reset. The phone just keeps showing the logo until the battery is empty again.
Edit:
It shows the Logo for a long time and after a while i get a white screen for <1 seconds and it reboots but still the same issue.
Okay as I told you the iPhone restarts after ~10 min.
I tried to keep the home and power buttons pressed until it restarts and it worked. I was able to turn the Phone off with a hardreset but somehow I couldn't manage to get it into DFU mode by pressing hard reset 10 seconds and then only home button 15 seconds.
When i try to get the Phone now into the resetloop again, it shows me after the first restard, that the battery is empty.
by Domsk
How long does it take until the battery empties if you just leave it?
by oldturkey03
I don't know. I had it connected to the Charger for the last four hours. Before that four hours I just charged it until it shows the Apple logo.
What i noticed:
When connected to the PC I can't do the reset loop (holding power and home button all the time), so i can't get into DFU.
The interesting thing is, that it is possible do a hard reset when it's NOT connected to the PC.
Connected -> Reset NOT possible
NOT connected -> Reset possible
Tried to get into DFU while the Phone was not connected, but it didn't work. It seems to have to be connected to the Computer to get into DFU.
Tried also to hold the homebutton and connect it to the PC but it didn't help anything. It just enters the bootloop.
I bought this iPhone intenionally and it was declared as faulty. I just wanted to have a cheap iPhone since im pretty good at doing hardware repairs to apple products.
The seller descirbed, that the iPhone got the Apple logo and didn't boot up anymore, so he took it apart and then it didn't do anything anymore.
by Domsk
I opened it and saw that he just didn't reconnect the connectors 1, 2 & 3. He also damaged connector 3. I slided the ribbon cable carefully back into it's place, even though the connector was damaged. Then I connected the rest of the display assembly and it got the described boot loop.
May a faulty connected ribbon cable in connector 3 cause any of these things?.
Is there another (Hardware)way to get the Phone into DFU mode?
Getting it into DFU with the buttons seems to be impossible.
Getting it into DFU with redsn0w and DFU firmware is also impossible because it needs to flash the firmware, but since my computer doesn't evnen recognize the iPhone you can't flash any firmware.
I saw a guy on Youtube getting his Phone into DFU by holding a small piece of aluminum foil on the top right corner of his iPhone with its display removed but this is to unsecure for me.
by Domsk
If I remember correctly #3 connects the ear speaker and proximity sensor to the motherboard. Having this disconnected will cause the phone to not recognize when your phone is close to your face (causing you to push buttons while talking), and/or it will cause the earpiece to not function.
by oldturkey03
