Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
Question Closed
Remove logic board to replace display module on Air 13" Mid 2011?
It's not clear if getting the video and antennae cables out will be a problem without removing the logic board, which I'm certainly skilled enough to do, but I'd rather avoid if possible.
Thank you.
Add a comment
1 Answer
Chosen Solution
The logic board needs to be removed on the 11" to replace the display but you can do the 13" with the logic board in. It's just a little tricky to thread the antennae cable back in. Definitely doable with little risk of damage.
Score 1
1 Comment:
That's what I thought. I was looking at Apple Macbook Air 13" Late 2010 Service Manual and it doesn't require removal of the Logic Board. I just wanted some confirmation on the Mid 2011. Thank so much.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 207
