Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Question Closed
Can Airport be fixed,? LCD came loose from cover.
The lcd screen came loose from the cover, that I can fix but the Airport isn't working too. Is their a relationship with the cover being detached ? If Airport has to be repaired, where can I find parts as i don't see them on this site.
Add a comment
1 Answer
Chosen Solution
The Airport Antenna & card is located near/through the hinges and around the lower end of the display. You'll have to look inside to see if you severed the antenna cable. Antenna cables often come bundled with cards or camera and display cables.
As a work around: you might be able to use a USB dongle wireless card with antenna.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 138
