Can't find a repair manual for Eclypse C800 anywhere!
I am attempting to replace the front glass on my LG Eclypse HSPA C800 but I can't find a repair manual anywhere on the web. Could you please help me?
These are the steps suggest by the manual:"
1. Disassemble Battery Cover
Take apart the battery cover using notch below
2. Disassemble Battery & Screw
Take apart the battery and remove screw ‘7points’
There are two types of screws. Type 1 is black screw and 1point.
Type 2 are silver screw and 6points.
3. Disassemble rear Cover
Take apart the rear cover out of Front cover starting from right side, back view,
4. Disassemble Main PCB
1)Take the key FPCB out of Main PCB
2) Take the Slide FPCB out of Main PCB
3) Take the RF cable out of Main PCB
4) Widen the gap between Middle frame and main PCB
5) Hook off the left side for disassembling Main PCB
5. Disassemble Middle Frame
Unscrew 2 points on Middle frame
Take apart the Middle frame out of Front cover starting from right side(back view)
Detach key FPCB from Front cover
Hook off the left side for disassembling Middle frame.
6. Disassemble Front Cover
unscrew 8 points at Front cover
Take apart the Front cover out of Hinge
7. Disassemble Lower cover
Detach cap from Lower cover
Unscrew 4 points on Lower cover
Take apart the Lower cover out of Upper cover starting from top side
8. Disassemble Slide FPCB
Detach the vibrator out of Upper cover
Detach the receiver out of Upper cover
Take the Slide FPCB out of touch Window FPCB
Widen the gap between Upper cover and Slide FPCB
9. Disassemble LCD
Take apart the LCD out of Upper cover
Tip: Easy to take the LCD module apart from bottom right side."
Let me know if you should need further help with this. My email address is in my profile, just click the avatar. Hope this helps, good luck.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 612
6 Comments
julien, just to clarify, your phone is a Lg Eclypse C800G?
by oldturkey03
yes, an HSPA LG C800 Eclypse. The front glass is cracked but the LCD screen inside still functions.
by julien
That HSPA confuses me ;-)
by oldturkey03
Sorry, It's just the type of mobile broadband technology.
by julien
Lets see what I find:-)
by oldturkey03
Show 1 more comment
