Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Questions View all
Question Closed
frozen on startup, will not pass apple screen
imac emc 2389 frozen on startup, will not pass apple screen, got hot to the touch right before this started. 4 led lights are on when started, when it's turned off all the lights go out the first one remains on for only a couple seconds after being shut down. I don't know what has overheated, the power supply? please help
Add a comment
1 Answer
Chosen Solution
See if it will start up from your original system installation disk. If so run Disk Utilities on the hard drive.
Score 1
4 Comments:
It won't use the disk or take any commands.
by
Disconnect the hard drive and try starting from your optical drive with your system installation disk. iMac Intel 21.5" EMC 2389 Hard Drive Replacement
by
Thank you so much for the link. I followed the steps but when I removed the LCD thermal sensor cable the light colored wire was out, I don't know if I pulled out or it was like that, guessing I pushed it back into the hole next to the dark colored wire. When I tried using the system installation disk to start up it went to and stayed on a screen with a file with a question mark flashing.
by
I tried to start again but only got a blank screen.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 392
