The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
319 Questions View all
The control display does not work.
"I have a Kenmore Elite HE3 dryer. The control panel does not work. when i open the door the inside light is on. When I do the diagnostic test of time up and down, the display lights up with code 88. PLease help. model #1110c82832100"
Score -1
Add a comment
1 Answer
Chosen Solution
Laurie, try to push the door switch button and see if the light goes off in the dryer. It is possible that this is caused by a bad door switch. You can check it for continuity with an ohm meter to make sure. Also check your thermal fuse which is located right next to the thermistor on the blower wheel housing.You can use an ohm meter to check it for continuity or take the wires off and jump it, use alligator clips or electrical tape to tape them togethe. This is for testing purpose only, DO NOT RUN your dryer that way. If none of this works, it is most likely the control panel user interface or the control board. Download the service manual from here for more information. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Laurie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 2,517
