Why is my iPhone warms up but not turning on?
Hi, my son dropped my iphone in toilet couple months ago. I got a new one, but I wasn't able to retrieve all my pictures and video, even some documents that were stored on that iphone. After carefully reviewing all the visor an guides I decide to repair iphone myself. I got a new battery and cleaned logic board, watch the YouTube videos and repeated all the steps. So far after putting it together iphone is still not turning on, but I feel the back of it getting warm. It's was doing same thing before I start repairing it. Is it completely broken or still have a hope?!
6 Comments
When you took the phone apart, did you see any signs of corrosion anywhere in particular? Where on the back does your phone heat up specifically?
by oldturkey03
@oldturkey03 I saw sighs of corrosion on each of the connectors, and camera connector. I soaked logic board overnight in isopropanol 91% and cleaned with tooth brush and also the parts that ididn't took out I wiped and brushed untill white corrosion was gone. It is hard to describe what part of the iPhone heats up the most. I am scared now to put it back on changer, I am hoping at least save this new battery for my new iphone, if it is not fried yet.
by Aleksandra Ward
Sounds like you did all the right things in cleaning it. Definitely cleaned it properly:-) Sometimes on water damaged phones it is the camera that causes overheating, as well as a shorted PMIC. Try to unhook the camera and see what happens.
by oldturkey03
So should I just leave it with charger on and let it to warm up???i thought this way it's damaging something in the phone or burning battery.
by Aleksandra Ward
There is warm and then there is hot :-) Have you checked your dock connector, make sure there is no corrosion on that. Do you have access to a multimeter or anything that can measure continuity? If you have a multimeter, check the voltage on your battery contacts and see what you get when your phone is plugged in. this could give us a bit more of a clue what is going on with your phone. If you leave it plugged in, do so for just a bit, not for hours.
by oldturkey03
Show 1 more comment
