Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 Questions View all
What do I replace if the inside of my iPod nano 6g screen is dirty?
I accidentally spilled some oil on my iPod's screen. It was not a lot and it did not get inside the USB nor the headphone jack. I immediately tried it afterwards and it functioned normally, except there's an oil stain in the interior of the screen.
So I followed a video to open up the device and I took apart the different layers of the screen to wipe each of them clean. However, the oil won't come off for some of the plastic layers behind the LCD screen.
Does anyone know what part I should replace? I'm not sure what the Touch Digitalizer is and I didn't see it inside either so I'm not sure if that's a problem. I know that my LCD screen is not broken, it's functioning properly. The glass part is good. It's just the plastic layer at the bottom of the screen (the last part of the screen) that is having a problem. Thanks in advance!
Score -1
Add a comment
1 Answer
Chosen Solution
xcody, for as long as it is working, I suggest to leave it as is. You could clean the LCD with +90% isopropyl alcohol, but again, only if you already have it disassembled. The LCD and the digitizer are fused, so if anything happens to it, you will have to replace the assembly. Not cheap and a PITA to work on ;-) Hope this helps, good luck
Score 1
Add a comment
Add your answer
xcody will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 507
