Repair information and guides for the fifth generation of iPhone. Model: A1387
Back camera doesn't work after screen replacement
I replaced the screen of my iPhone 4S. I've done many before, and I'm good at it, I would like to think.
However, when I tried to go onto the camera it just loads the shutter image and wont go any further. The controls at the bottom flash a few times, and some times it will go back to the apple logo and then onto the lock screen. (Not like a reboot, it only takes about 8 seconds)
I ordered a new camera and replaced it, still the same. I've even swapped it for a one I know works and still the same.
Any ideas?
Score 1
Add a comment
Chosen Solution
I have seen this once and fixed it by restoring the phone several times, that's all I have to offer and hope you get it fixed, good luck, If this Answer is helpful please remember to return and mark it Accepted.
2 Comments:
Can you expand? How can a hardware issue be repaired by a software method?
by
The way I read your question it sounds like you have ruled out hardware, and your symptoms are the same as the one that I fixed with the restore, unless I'm reading your question wrong,,,, when I was stumped by this I called Apple support and they are who told me to restore, and it did finally work after numerous restores,
by
Add a comment
i have the same problem, I've had it for a couple of months now, never found any solution to this. I think it's a motherboard problem, where you connect the camera.
Add a comment
Add your answer
Jamie Simpson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,417
