Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 Questions View all
Question Closed
Takes a long time before it boots up!
When powering on the CAPS Lock light flashes slowly 4 times, the fan is running high and I have to wait sometimes up to 10 minutes before it boots. Sometimes it will boot up less time than this and some of the time it can take half a day to boot but when it has booted it runs fine.
Thanks for your help.
Paul
3 Comments:
Paul, try to set your boot up sequence to your CD drive and use a Linux Live Cd to try to boot up. Let us know if that is working faster. It does sound like you have either a hard drive issue or a OS file issue.
by
Thank you for your reply,
I have tried all above and still will not boot. Is there anything else that I can do?
by
So what happened when you booted with a different OS from the optical drive? What model Compaq do you have?
by
Add a comment
1 Answer
4 lights blinking usually indicates memory error.. try taking out one of the memory sticks and swap them around and see if the computer boots.. :) Plus, I need to know the model, because some of the newer laptops have additional things that could go wrong that are indicated by the blinking lights.. I suggest you google something like this: (model computer) light blinking 4 times...
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 496
