Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
earpiece not working but loudspeaker or earbuds do
iPhone 4- Headphones or earbuds still work when plugged in. Loudspeaker at base works if speakerphone chosen. Earpiece has suddenly stopped working. Had been using headphones just prior. Is this a function of the headphone jack not releasing the sound circuit back to the earpiece or the earpiece itself just died? So do I need a headphone jack assembly or just an earpiece speaker?
Score 3
1 Comment
my@iphone 6+ ear piece side is not working but d speaker does pls what can i do
by
Add a comment
Most Helpful Answer
Disclaimer! If my troubleshooting steps make the device worst then it already is, I am not...i repeat, I will not be responsible for it. So use these steps at your OWN RISK!:
I work as advance tech special for a wireless company. What normally work for that specific device is:
1) Plug a headphone into the device
2) Make a test call and make sure you are able to ear call on headphone
3) Toggle the Speaker on & off and make sure you are able to hear call on the headphone
4) Toggle Speaker OFF
5) Remove headphone
6) You should be able to hear from earpiece now.
7) If all fails - Restore via iTunes!
By: The Subliminal Poet (follow me on twitter, fb, and instagram)
Score 8
6 Comments:
This worked perfectly first time I tried it. Phone is doing it again but cure doesn't seem to be working :(
by
Just saved me a trip to Apple! Thank you!!
by
Awesome !!! its worked perfectly...now its working... thank you!!!!
by
Worked for me. Thanks
Len D
by
Great!!! Worked for iPhone 6s plus. Thank You!
by
Show 1 more comment
Add a comment
Usually that would be only the earpiece, that's where I would start, a link to the part, https://www.gounlock.com/details.php?ite..., a guide, iPhone 4 Earpiece Speaker Replacement, good luck, If this Answer is helpful please remember to return and mark it Accepted
Score 1
2 Comments:
Well, it was not the earpiece. Ordered one but through trial and error determined that by holding the phone upside-down and re-inserting the headphone jack several times I could get the earpiece to work again eventually. As long as I didn't use the headphones or earbuds the earpiece worked for days. It always failed right after the headphones were unplugged. Ordered the headphone jack and volume control cable and tore the whole thing apart to replace it. Seems to be working fine now.... certainly don't want to do that again anytime soon!!
Since I had the phone apart I replaced my funky Dock Connector too.
Rick
by
When absolutely none of this worked for me I took a screwdriver and whacked the !&&* out of the top of my phone. NOW IT WORKS! Probably will not work for most people though. Of course I already reset my phone losing my settings and my purchased ringtones forever. I HATE Apple!
by
Add a comment
Koo.. It worked for me..
Score 1
Add a comment
This worked for me ..... Your awesome dude!
Add a comment
This worked for me. Thank you so much!!
Add a comment
Thankyou sooooooooooo much!
I tried all the other solutions i found online, compressed air into the headphone socket, pushing the jack in and out, squeezing the speaker face and even a restore.
I was pretty much ready to start crying when i found this!
Thanks again you wonderful genius! :D
1 Comment:
Ok so my outter speaker works perfectly fine, but the ear piece speaker doesn't work properly, it fries and make baffling sounds, when I make and receive calls I have changed my speaker, I have updated to 8.1.1, also restore my phone. But it works perfectly fine when I use viber and Magic jack, or even Facebook messenger so what's the problem??
by
Add a comment
Add a comment
Try switching to Android... That's always worked for me.. Just saying, lol.
vviii
Add a comment
First restart your device, then blow the headphone jack and plug your headphone, listen to something first , than unplug it, and test it out
Add a comment
dear sir i cant hear sound during call but hear sound when i on the speaker kindly help me about this problem
Add a comment
My phone earpiece not working I don't know why
1 Comment:
One this should be another question, and 2 did you even read anything in this post?
by
Add a comment
Add your answer
ramosel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 85,825
