MacBook Pro models with 13" displays
4963 Questions View all
hooking up to Viewsonic monitor VA720 15 pin HD D sub (hd15)
Dropped the Mac the glass broke screen showed a whtie streak down the middle.
Replaced the screen and it doesn't come on, doesn't show anything.
To check if anything else might be broken, I want to try use the mini display port to connect it to an external monitor that I have, Viewsonic VA720 and I'm not sure its compatible.
I know I have to get a cable to connect to the monitor, any suggestions on where i might get one. If its compatable with ehr monitor.
Comments:
check the link from "Gabe" on your other question about the same issue.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Yes you can, just use one of these adapters!
Score 1
Add a comment
Add your answer
gnrnld will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 233
