Damaged LCD, shattered the front display and bent
Closed the car door on my iPhone 4S. And the display panel and LCD inside is damaged. It's little bit bent too, is it possible to fix it??
If your phone is staying on with the damage then yes you can fix it, if not then maybe, the screen replacement is a straight forward fix, here is a guide, iPhone 4S Screen Replacement, also you say it's bent, do you mean the steel mid frame ? A picture would be nice, if it's very slightly bent it may be OK to use it, but if it's bent enough to let liquid or dust inside your phone then you really should replace it and it's not a problem getting new ones, even color conversion kits for around 40.00, here is a link, https://www.gounlock.com/search.php?prod..., good luck
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 212
