Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
My iPhone 4s doesn't connect to any network. Is says "Searching"
My Iphone 4s doesn't connect to any network. Is says "Searching" and then goes to "No Signal".
If I go to "Carrier" in settings and disable the "Automatic" option it finds all the available networks in range.
The other thing is that I have normal wifi connection. I tried to Restore in iTunes but the it doesn't work.
Can anyone help me?
Thanks in advance
Add a comment
Most Helpful Answer
Your wifi and cellular antennas are not 1 and the same so you can get one signal without the other, are you paying for cell access and if so, what carrier ?
Score 1
4 Comments:
My Carrier is Globe Telecom here in the Philippines. if you go to settings - phone my number will appear. i tried to change my sim 2x but the same problem.
by
The next thing I would do is clean the sims reader real good, to do that you would need a total teardown because you need to get to the underside of the motherboard to clean the sims reader, iPhone 4S Teardown I would use a pencil eraser to polish the sims contacts, if that doesnt work for you then you should try alcohol and a toothbrush, good luck and keep me posted !
by
Thank you mitch.
by
Your welcome and hope that works !
by
Add a comment
other networks
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,636
