Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
How can I fix this?
My Ipod touch 4th gen. screen was broken and I repaired it. Now when I try to turn it on, a white screen shows up.
Score -1
Add a comment
Chosen Solution
make sure all the connectors are connected and try doing a iTunes restore
Add a comment
do you sure the konectore scren put correctly? make sure the screen type corect too
Add a comment
If the LCD connectors are properly connected then try resetting your device by pressing and holding home and power button until the screen goes black and turns on again. If this thing doesn't help then you may need to go for LCD replacement.
1 Comment:
Did you bother to look at the date the question was asked? I doubt bakerkylee still has a problem here.
by
Add a comment
Add your answer
bakerkylee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 199
