Can I insert 120Gb HDD into my iPod Classic
Hello.
I have an iPod Classic A1238 with broken 80Gb HDD.
Can I replace it with HDD of a higher volume? For expample - 120Gb or 16-Gb?
Hello.
Alex, yes you can. The model iPod that you list should have a 120 GB 4200 RPM ATA-66 hard drive with a ZIf connector. The only thing to watch out for would be the thickness of the HDD. Something like the Toshiba MKxx31GAL series should work without difficulty. They do go up to 240 GB. The only other thing I suggest is that you replace the hard drive cable as well. Make sure that you get one for your Drive. I have had trouble with replacing a Hitachi drive and using a Toshiba cable ;-) Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 1,162
