Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Half of screen is Blue/Black
I was followed the guide to fixing the power button. Everything went well until i turned it on. I can only see half the screen the other half is black. I have tried tightening the screws and reconnecting the screen connections with no luck. The touch features are still fully functional.
Any suggestions?
Score 1
Add a comment
Chosen Solution
Try to change your lcd and touch its comes altogather any way its lcd problem
Regards,
Add a comment
Looks like you have either a bad video connection, or an ESD issue while opening and handling the the internals of the phone. If all you did was change a power button the only possible causes would be your LCD/Digitizer connectors either are not on all the way, damaged, or something got pinched or zapped with electrostatic. Were you grounded and did you take the logic board out?
1 Comment:
I did take the logic board out and I doubt I was not grounded.
by
Add a comment
Add your answer
spybot1331 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,983
