The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
410 Questions View all
black screen, with working sound
every time i turn on my Xbox the screen goes black and the sound starts to work , what is wrong with my Xbox ?
Comments:
Which model Xbox is it?
by
It's a halo 3 edition
by
Once I do the steps u told me it shows a black line continues to go down the screen Wat do I do next ?
by
So, is the whole screen still showing black, or is it just a line that moves down?
by
Did you hook up the cables properly and put them in the right output
by
Add a comment
Chosen Solution
Jonathan, try this
1. turn on Xbox and leave it on for 10-20 sec
2. While still on, disconnect and reconnect the av cable. You will see the screen go black.
3. Reset your xbox
Score 1
Add a comment
Failing fiddling around with the cables (it's always a great idea to check cables before you go on to anything else) you may have an issue with the motherboard. There is a chip on the motherboard called the "HANA" or "ANA" chip that is responsible for video output. I'm sure you have heard of the Red Ring of Death? it's basically a crack in the solder that sits under the CPU or GPU which can sometimes be fixed by reflowing the chip (Reflowing is the process of heating up a chip to remelt the metal solder points underneath to fix and defects/cracks in the solder).
The HANA chip can sometimes also suffer from this defect. This causes no display issues like you are describing. As a result, usually a good reflow of the HANA chip will fix this issue, only problem is that you gotta open up your xbox 360 and do the reflow. Be careful though as it is possible to overheat these components. Alot of people use a heat gun, this is a very crude method though as you can't measure or regulate temperatures well. If you want to do it right, you will need access to or get a reflow station. Other then that, try a heat gun if you think you have nothing to lose. When reflowing, you do not want to move the board while it's hot. Reflow the board then give it a good half hour/45 mins before moving it.
Good luck in your endeavors in trying to rectify your problem.
Update
Add a comment
Add your answer
Jonathan will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 53
All Time: 3,772
