Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
Really weird white screen with black line in it after repair.
I change my ipod touch 4th generation screen and I got a white screen. Here's a link http://www.imgur.com/sjwhg
Please help me!
Update
I changed the screen and it worked. Thank you
1 Comment
Glad you got it to work.
by
Add a comment
1 Answer
Chosen Solution
Philippe Dupuis, recheck your work. It is possible that your connector is not properly seated. Check all the pins to make sure they are aligned properly. Ultimately, looks like a bad LCD, but try the connector first. If that is all a-okay you do need to replace your LCD. Hope this helps, good luck
Score 1
3 Comments:
Thank you, I will try that but the thing is that LCD was working perfectly for a few minutes then I turned off my ipod and close down my ipod and this thing showed up
by
I understand, and I know it's a PITA. Hopefully it's just the connector not seated or the pins inside the connector slightly bed.
by
Okay thank you
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,206
