Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1277 Questions View all
Satellite Pro C850-14C Maximum Expandable Memory?
What is the maximum amount of RAM I should expand my laptop to for optimum performance? I currently have 2GB of DDR3 1333mhz & I find it a bit slow. I was thinking of going to 4GB, but the toshiba website says that it can expand to 8GB. I'm just afraid that my processor, which is a IntelĀ® CeleronĀ® Processor B820, won't be able to utilize the full 8GB... Any help with this would be great thanks
Add a comment
Chosen Solution
Generally speaking if the maker indicates the computer can use 8 GB of RAM it should be able to use the full amount. If you have doubts I would contact Toshiba customer service for confirmation. Good luck.
Score 1
1 Comment:
You usually get the biggest improvement by increasing your RAM, your processor is a close second. So, go with the maximum that you can get/afford. Yes, your computer with its current processor will manage 8GB just fine.
by
Add a comment
Hi, according to the specs on this website (http://uk.computers.toshiba-europe.com/i...) u can upgrade to 8gb 1333MHz ram. There will be no problem with ur processor being unable to handle the ram. What I would recommend is go for 4gb in total ram, also make sure u have the 64-bit OS, because 32-bit can only handle 3.25GB of the total ram installed. Write back on what u think. Good luck.
1 Comment:
On a second thought if u r willing to spend a little more money I think u should upgrade ur processor. Follow the link for compatible processors, but keep in mind not all those processors might be supported by ur motherboard. Search around a bit and I am sure there are bargains on ebay. Good luck.
http://www.cpu-world.com/Sockets/Socket%...
by
Add a comment
Coming from the 2020 here - I have a Satellite Pro C850 myself and I can tell you it will support a Core i5 2450M, and also an i7 2670QM and will do 8GB of RAM. I also believe it can support 16GB of RAM but don't quote me on that. The chipset also supports 3rd gen chips, but again, I don't know if they work.
1 Comment:
Have that one on the table ( Satellite Pro C850 PSCBZA-003005 ) - it is with Core i5 3rd gen. 16 GB confirmed in this model by Toshiba http://anz.dynabook.com/products/compute...
by
Add a comment
Add your answer
Richard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,148
