colored vertical lines on my SAMSUNG UE 40 D8000
My LCD TV Has Colored Vertical Lines on Half of the Screen
It´s possible that the problem may be due to a damage in the t-con board, it acts as a bridge between the LCD panel itself and the main board.
If there's anything wrong with the t-con board, it could produce a faulty display and colored lines in the screen.
The board itself is most often found in the top center of the back of the TV, often covered with an aluminum panel. Replacing this part can be a challenge, so if you don't feel comfortable working on your TVand you do not have experience on electronics repairing I consider you should search a tech. I would recommend you but you should search near your zone.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,730
