My iPhone is dead
Hello,
My 3gs iphone does'nt turn on and not chraged.
I have allready replaced the battery. Any suggestions?
Hello,
did u drop ur phone? or is it water damaged? if u dropped ur phone, it could be that u have loose cable inside. Usually the number 4 cable (the home button cable) is out of its socket. u can easily snap it on to fix it. But if u have no loose cable, it could be ur power flex cable that is busted. U can replace it urself....just search for "power flex cable replacemnt" on youtube. Gudluck....
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 457
3 Comments
check the dock connector for any broken pins and corrosion. try a new cable and use an AC adapter to try to charge. Use a multimeter to see if your board gets power.
by oldturkey03
have u tried pressing the power n home button?
by wawan
yes but the phone simply doesn't respond for anything
by abc
