Model A1106 / 1280x854 screen resolution
90 Questions View all
Question Closed
it does not start, gets caught on the screen of apple
My PowerBook does not start, i have changed the memory ram for new ones, tried safe start (with the "shift" button), tried boot from leopard dvd (witch the "c" button), can any one help with another ideia?
Add a comment
Chosen Solution
You can try disconnecting the PRAM battery--if it then starts you should replace the battery. See if you can boot to the OS disk and if you can go to utilities and run disk repair until it says no trouble found. You should also try reseting the pram and the PMU. Ralph
http://support.apple.com/kb/TS1367
http://support.apple.com/kb/HT1431
Score 1
1 Comment:
thanks a lot, Ralph,
i tried resetting PRAM Battery and PMU, it doesnt works,
i could start using the "apple button + s",
but i cant boot from OS disk, also the OS disk is stucked into the optical drive
searching over the net, i found that it could be the hard drive so i´m going to replace it.
by
Add a comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 966
