Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
169 Questions View all
Install Memory Ram Failed, Ram Holder Broken/Crack
Hi today i just upgrade memory ram, but the problem is 1 bank memory holder is crack or broke because i push too much.
So right now my mac mini only detect 1 bank memory, If i go to apple to fix it, do you think how much they will charge me? Since my mac mini is new only 4 days used.
Thank You
Add a comment
Chosen Solution
Unfortunately for you Tungshi, if the socket is broken (even if it's a minor damage) Apple will not cover that since they provide an installation guide for installing and/or removing/upgrading your Ram modules.
http://support.apple.com/kb/ht4432
"Gently spread the clips at the ends of the top memory module just enough to let the free edge pop up."
"Carefully press the notched edge of the new memory module into the bottom slot while keeping the opposite edge slightly raised."
Sorry man.
Add a comment
Since your mac is only a couple of days old, I would suggest taking it to an apple store. The only possible way to repair if the socket is broken is to replace the socket. Write back on what u did. Good luck.
Comments:
Somebody told me, if i already open and then something happen the warranty will be void! I just worry apple will be charge me over $500
The clips still ok, only small plastic is crack...
Thank's for your respond
by
Add a comment
Add your answer
Tungshi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,567
