The screen doent light up
theres no back light when i turn it on.it will not light up at all even though its on
edwin, it is possible that your backlight has failed. the usual way of fixing that, is by replacing the front display assembly. There are chances that it could be the IC on the logic board, but start with the LCD first, it's the easiest to fix. Use this guide to work on it. Hope this helps, good luck.
You say your iPod won't light up? You can force your iPod into recovery mode then try again. The given tool is a free and safe program especially designed to enter and exit iOS recovery. Don't need to restore and connect to iTunes, just one click to make it!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 307
