The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
My Mac Pro don't start the OS X Leopard
Hi,
My Mac Pro start the OS X Leopard after Apple Logo give a kernek panic.
I test everything, inclued with ASD 108 for my Mac e don´t detect nothing worng.
Any body who idea what going on?
Thanks a lot.
Regards.
Att;
HkN
Add a comment
Chosen Solution
You sound like you are describing a ram issue. The ram is by far the most likely cause of any kernel panic that your computer experiences. I would remove all the ram sticks in your computer. This guide will show you how to remove an reinsert ram into your computer:
http://eshop.macsales.com/tech_center/ma...
After you remove all the ram, reinsert 1 stick into slot 1 and boot up. If there is a kernel panic, then reinsert a different stick and try again. This will show you what ram sticks are bad (kernel panic) and which ones are good (boot up). If you get a kernel panic on every trie then you most likely have a different problem. You ram might also need to be removed and reinserted. You cannot use a ram stick it it is bad. You may even want to buy new set from OWC to replace the aging set that you currently have installed. If this is not the case, then you may also want to try the hard drive. Hard drive caused kernel panics are far less likely but are still a possibility for any mac. Tell use what you find so I can provide any further assistance if needed.
Hope this helps.
Score 2
1 Comment:
If all sticks are bad in slot one try slot two. +
by
Add a comment
Hardware issue. Could be a bad processor or bad RAM.
Add a comment
Add your answer
HKN will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 511
